When you say you had 6 pump failures in one year what do you mean by pump failure? Did the crankcase fail or did the head of the pump wash out or was there some other failure. Were you using the correct pump for the application? Was the pump set up correctly? At what pressure and flow rate were you running the pump? Was the pump fed with a gravity tank or fed with city water pressure? There are a lot of things that will cause a pump to fail in short order.
pumping system was supplied by kleen rite, purchased 4- 2 bay pumping plants, equipment made by hydro spray to kleen rite specifications, pumps are easy to rebuild when the top end goes bad, THEY HAVE TO BE EASY TO REPAIR BECAUSE THEY SO MUCH.
pumps seals seem to fail often 1100 psi running, hydro spray says they built the units to kleen rite specifications, one of kleen rites named brand unloaders jammed and there was one seal kit lost.
HAVE FOUND THAT CAT SEAL KIT DESIGN DO NOT HOLD UP THAT WHY WE WOULD RECOMMEND AN OTHER PUMP COMPANY, THE OTHER REASON IS THAT CAT PUMP PERSONAL HAVE GOTTEN SMUG AND REALLY DONT CARE.
NOW THAT THE COMPETION HAS GOTTEN A LOT BETTER, CAT PUMP PRODUCTS HAS STOOD STIL
Cat is quick to blame every body by saying its not their fault, yet THEY talk us at the ica show it your fault if the don't replace the pump seals yearly to prevent head damage. may be we are in love with the 623 pump because it will run for ever, BUT 530 IS A TROUBLE PRONE LOW END PUMP THAT WILL BE CHANGED OUT IN THE FUTURE, AND NOT BY A NEW GENERATION CAT PUMP PRODUCT. wE SPENT GOOD MONEY FOR A DEFECTIVE DESIGN
