Need help
Mak
could someone tell me why my foam brush is not getting product? Only Air and clear water coming from brush it has flo jet pump
This has been discussed many, many times. Do a search, and look at anything that relates to your system. In the future, try to make your thread title more descriptive.
Look at everything, make sure you didn't do something like push all the extra hose into your pail so the pickup looped up out of the chemical.
Do you have any soap in the chemical holding tank or is it all water? Is your hydrominder pulling chemical into the tank? Pictures are always nice
Mak
Chemicals completely full in jug pickup completely submerged
Keno
What about after the hydrominder in the mixed chemical holding tank? As IB Washin said, you have plain water in your mixed chemical holding tank if that is what you are getting out to the bay. As Randy said, check to ensure your hydrominder is working and pulling chemical to dilute. Is your chemical feed into the hydrominder staying full - ie is your foot valve still good? All of this is assuming you have hydrominder to dilute chemicals. Need pictures of your setup
Take the suction hose off your hydrominder and put the next larger size tip in the hydrominder.
