New Petit is here.
APW did you get the single or dual pump model? LOcal tech that installs them says the dual pump model is the way to go.
APW
South
What enhancements to the wash does the dual pump give you over the single pump?
With the dual pump you can wash the sides and the top of the vehicle at the same time whereas the single pump model has to do sides and then top or vice versa.
washnshine
NY
I see - thanks. I didn’t realize that - must be all the videos I have watched have the dual pump because that is how I have always seen the machine operate. I would definitely want that if I were getting that machine.
As I understand it the single pump could also cut down on the number of passes for other services you could program.
  • Like
Reactions: APW
Martins
Its going good. All the equipment is set and halfway wired and plumbed in. How wide and long is your bay?
15'9 wide, 28.5 long 11ft 1 3/4 tall
