High pressure chemicals (soap and wax) are not coming out of the spray gun. Both are gravity fed, mixture in the hydrominer is good since the other 3 bays are working correctly. Prior to this issue the pump was getting starved of inlet water because of electrical issues but chemicals were coming out. Once the water pressure was back to normal on the inlet side then I was having this issue of no chemicals. I reduced the amount of inlet water and chemicals would come out but the pump would pulsate.
I’m trying to figure out what the large cylinder is that the chemical lines are going into and if that would be my issue.
Thanks in advance for any assistance and advice.
