Update...The Sensortrons and LED 7 timers have been installed about a month and I can say it hasn't been without issue. I've had to send 2 timers back and 2 sensortrons had issues of rejecting
coins. One acceptor would reject the first 4
coins then accept the next 50. Let it sit for 5 minutes, then it would repeat the same thing.
The first led7 would jackpot and rack up 100 minutes on the timer. Dixmor said it could be caused from a chattering switch in the acceptor, but switching out the timer with a new one fixed the problem....Same acceptor still working today. Dixmor said the problem turned out to be an opticoupler issue. The second timer quit crediting
coins. This one made some unhappy customers.
After talking with Dan at Ginsan, he said the acceptance issue was caused by a dirty
coin path and to clean the
coin path with alcohol per instructions. Doing so didn't help a bit.
I have this same combination in my bays and never have an issue. Been in service for over 25 years. Seems to me 50% failure rate is a little high for new equipment.
For now, I have everything working correctly and will bench test the faulty sensortrons before sending them back.
Am I the only one experiencing these kinds of issues with this combination?I've read about the sensortrons rejecting
coin issues, but I thought the led7 was a bullet proof timer. Should I give the sensortrons a bit more time or have some slugbustes on the shelf waiting to go in?
