washnvac
I just ordered an oscillator motor/gearbox. Guess what? The price actually went down $110! That is a big thumbs up to JC for bringing that down to a more realistic price.
Actually, it was the motor that went on this one. The gearbox is still in good shape, so I will save it. I am going to take the motor to a local shop to see if they can rewind. Once I get an estimate. I will decided if it is worth it.What is the problem with your gearbox?
Could you give us more info on that Lesson motor? Model, etc?. I have replaced 2 oscillating motors in the last 6 monhts. Both of them the gears were striped. It seems like the gear on the motor shaft is steel and the bigger diameter ring gear is brass. The teeth on the brass gear were chewed right off as if the arms were stuck in position and the motor kept running, allowing the steel gear to strip the teeth off of the bigger gear.I think they wrap them to keep some of the water out. I have found a Lesson Stainless steel motor that replaces the drive wheel motor instead of the pot metal Baldor and it is cheaper also.
I just got a quote to rewind these motors. My local guy wanted $250. I thought it would be better to buy a new motor.Actually, it was the motor that went on this one. The gearbox is still in good shape, so I will save it. I am going to take the motor to a local shop to see if they can rewind. Once I get an estimate. I will decided if it is worth it.
Do you know why they wrap the motor with that canvass? It seems to me that would cause heat build up, and premature wear/ failure. I have taken them all off.
New price was $439 for motor/gearbox. Previously they were $550.What is the new JC price? I bought one off my distributor about 4 months ago. I think it was around $450.
Sounds great! Who do you order off of? I have local Baldor dealer. When I talked to Baldor direct they would not give me anything either.I got a call from a friend who has been on the phone with reps from baldor. he finally got a parts list and cad drawing for the gearbox guts. Retail cost to replace gearbox internals is less than $100.00 I will try to scan and upload when I get a copy.
For some reason I didn't have the option to edit my post - I wanted to add that I have not installed it yet, but it measures the same as the damaged gear. I will install it this week and post here as to how it fits. I don't want someone to order it based on what I have said when I have not installed it yet. Sorry, I jumped the gun by stating that it is the correct gear before installing it.The driven gear is the correct gear and shaft for the osc. motor gearbox.
