Patch Water Softener tank?
the fiberglass tank on my water softener sprung a leak overnite. What should I use to patch it? Tiger hair?
TIA
The softener tank has an inner liner that actually keeps the water in, and the fiberglass only gives it strength. You can't patch it, at least not from the outside.
You'd have to take it out of service, inspect it from inside to find the crack and find something that can seal it. I don't even know if there is such a product, but the tanks aren't very expensive. I wouldn't put the effort into it.
It CANNOT be fixed from the outside. It's two separate layers and the leak is probably not even where you see it.
it's a 16" x 65" tank; dealer i bought system from quoted $768 + shipping, so just under a grand.
unless someone knows a better priced source?
Unless they are quoting you the tank with all the media that is about double what our full list price is.
any fix will fail probably sooner than later. I'd get a different quote from other places. I can get a complete charcoal filter with head and charcoal at that price. You might be able to get a complete softener tank w/resin at that price or just a bit more.
Shop around
I buy any softener related stuff from wood brothers Good prices and support. Check with them before you buy elsewhere...
