I have 2 L-360's that are some of the early machines (Serial Number 00015 / 00016) and we have been having an issue with both bays not spraying presoak on the first pass. The arch will go around the vehicle but nothing is coming out. On the 2nd presoak pass there is never an issue. This has been a gremlin for us for over a year now. Our wash techs have been called in on a number of occasions and have changed out check valves, solenoids, injectors, output relay cards, etc. all to no avail. The last fix, which seemed to work for about 6 months was making the first presoak step the LP Wax step in the programming, and wiring the soap solenoid with the LP Wax wiring. It was thought there might be an issue with the PDQ software and this work around solved the problem for a while.
Now we are heading into the busy wash season and on about every 40th vehicle, we get a call that there was no soap on the first pass. It's frustrating because the customer thinks we are trying to skimp on the wash, and that clearly is not the case!
Does anyone have any suggestions on what else to look for? Has anyone had this same issue and found the root cause of the problem. I appreciate any and all replies at this point.
Thanks
Thanks
