Pipe Insulation
Bubbles Galore
Michigan
I've got some fairly large copper pipes feeding my hot water tanks and such and want to insulate them against thermal loss. I can't find the split foam covers for these larger sizes, what are you guys using to keep your pipes insulated?
Thanks!
John
http://www.mcmaster.com/#thermal-insulation/=hczy98
There are several plumbing supply companies local to me where I can buy it - Home Depot/Lowe's don't carry larger than for 3/4" pipe.
The run from the boiler to the tank is pretty short and there's no circulation between them, so I've never worried about insulating.
Bubbles Galore
Michigan
Thanks MEP, for some reason, I have alot of exposed copper that loses more than its fair share of thermal energy. I will check out the link. Thanks!
Whale of a Wash
5 Washes 36Bays 2Vectors
Fargo,ND
Or use two pipe foams- one on each side and zip tie around them.
