I know some of my fellow operators have actual hands on PLC experience as it applies to latching on the following:
---6.5VA dog wash 24VAC solenoids
---13 watt 24VAC Asco Solenoid
---Usual 24VAC coils on the more commonly sold Car or Dog Wash magnetic contactors in Car Wash Catalogs
---Laurel Electronic 24VDC shelf tripper motors
All of the above motors have inductive loads. In general: Do they require diodes to protect the output solid state relays of most PLCs? From actual experience are some of these items safe to run directly from the PLC output? I am aware of the voltage specs & ranges so that general configuration would be OK.
2nd question: Would the Mars bill acceptors or Slugbuster 2 or 3 coin acceptors all require 24VAC input specifications? By 24VAC i am referrring to the output pulse that would be read by the PLC input?
Thanks
Thanks
