I put one in at our company wash to test and it worked great no problems.
Can you provide us with more details?
When did you install it? Self serve bays? Automatics? Where is your installation located?
Thanks
I think we installed it in November in 1 self service bay and tested to see if it would work, it did freeze once but that was because i did not have it adjusted rite i readjusted and then after it got really cold and the bay did not freeze i installed it on the other 5 bays. no freze ups at all. Location is in CT.
You do have to work with it to get it adjusted so you dont use to much antifreeze. I would say to do 1 bay first and make sure is is adjusted first then turn the rest on.
I no we where at 0 plus the wind chill. I no polar freeze is made in michigan and i belive he has been down to the temp you are talking about.
Are you using rv anti-freeze? That seems kind of pricey when compared to something like methonal. How much do you use? Any thoughts on that?
It doesn't purge the line with antifreeze - it purges with air, shoots just a small amount of antifreeze to displace the small amount of water that stays in the hose and purges it with air again.ScottV said:I was wondering about purging the RV antifreeze out of the line when the customer wants to wash their vehicle. Do they seem to care when its pink antifreeze spraying at first?
It's for the wands. You'd have the foam brushes freezing up while in use if you didn't use methanol.
