What are you guys using for polytube fittings? I have a leak that is hard to get to and it has those brass nut and sleeve type fittings on it. To make things worse it is a built manifold with several threaded fittings and of course it is the middle part that appears to be leaking. I just want to use some type of push to connect fittings to repair it and stock them for other repairs. When looking at what is available the selection is overwhelming. I want them to hold up to vibration and high pH. Almost all tubing we have is 3/8" or 1/4" OD but the pipe threads are 1/8, 1/4 and 3/8. Gee, it sounds like I would have tp stock a bunch of different fittings.
