Possible to get an email or text if changer is down?
Austin603
Fort Worth TX
Don't know all changers but you would need a small single pole relay that has a operating voltage the same as your light. When the changer powers the light it would also power the relay, which would close the contacts on the sensor and then the yolink app would send you a push notification that your changer is down. If your changer is a Hamilton I'd be tempted to buy the factory kit from Randy- that's a reasonable price and I assume it's plug and play.
You'll also need a hub at the car wash to connect to the sensor. You can install another Speaker hub at your home or office and it will speak to you and say "left carwash changer is out of service" or similar if you like. All these devices that yolink sells range from 25-35 dollars and are pretty handy. You can also connect that relay above to pressure switches on your air and float switches on your tanks, etc.
Thanks for the reply! This is all super helpful!
Thisguyswash
It would be nice to get an alert if a change machine goes out of order (service light comes on). Since the service light is powered by a signal wire I am sure it’s possible to connect it to some sort of device that could then send me an alert. Anyone done this? Appreciate any ideas.
I do this with a cheap PTZ camera in my changer. It's programmed with three positions, one to see the LED to monitor for errors, one to check the level of the coin hopper, and one to monitor the bills. The video is left on the LED position and monitors for a flashing LED. This is done with my Blue Iris camera server software. It can be configured for all kinds of actions. Email and push notofications straightforward to setup. The camera was $40 and blue iris was $50. It's all hosted on site so no cloud fees or security issues.
Fatboy769
Living the American Dream
Irmo, SC
Just installed the Yolink device and hub that @Greg Pack linked in this thread, to email me when a customers automatic goes out of service. Works perfectly!
Mchas
Nice! I would still like to do this with my Rowe changers - anyone know what relay I would need?
Mchas
According to the Rowe manual, the out of service light is 12vdc
Thanks! I’m not so good with this sort of thing - could someone point me to a relay that would work for this? And how exactly I need to wire everything up? Appreciate it!
I'd probably call Rowe and see if they have a out of service kit, one that's plug and play. I don't know how the Rowe BC1400 out of service light is wired, is it hot all the time like the Hamilton out of service light or is it off and they put power to it to make it come on. We've gotten rid of all the Rowe changer up here in my area years ago.
Mchas
I still haven’t quite figured out what parts I need to make this work, and this weekend both of my changers went down at the same time so I would really like to get this working. Appreciate any help!
Here is the description from the Rowe changer manual of the service light:
“The OUT OF SERVICE lamp is controlled by the switched + 12 VDC supply through U7G Pins 7 and 10. Whenever the switched +12 VDC supply is ON, the power control relay is energized and the OUT OF SERVICE lamp is OFF. Whenever the switched 12 VDC supply is turned OFF, the power control relay de-energizes and the OUT OF SERVICE lamp will be lit.”
Does that help determine what relay I need?
Get out your volt meter and check the voltage on the light to ground. Then force your changer to go out of service and then measure the voltage again. Then report back.
Mchas
Finally got a chance to check. It’s 5V DC when on, and 0V when off.
Mchas
I was finally able to make this work! Got a 5V relay and the Yolink sensors and hub mentioned earlier and hooked it all up and it works great. Just wanted to say thanks to everyone who helped!
