J jack954 Active member Joined Jul 11, 2020 Messages 202 Reaction score 128 Points 43 Sep 15, 2021 #1 finally made the switch after reading about it awhile back. cheap transition with excellent results. foams up real nice and change over time is 4-5 seconds compared to 20 seconds thru the high pressure hose
Eric H Well-known member Joined Aug 30, 2007 Messages 1,326 Reaction score 823 Points 113 Location Leominster, MA Sep 16, 2021 #2 are you located south enough to not have to run weep in winter?
J jack954 Active member Joined Jul 11, 2020 Messages 202 Reaction score 128 Points 43 Sep 16, 2021 #3 yes
J jack954 Active member Joined Jul 11, 2020 Messages 202 Reaction score 128 Points 43 Sep 16, 2021 #4 i meant yes i do have to run weep
Eric H Well-known member Joined Aug 30, 2007 Messages 1,326 Reaction score 823 Points 113 Location Leominster, MA Sep 16, 2021 #5 jack954 said: i meant yes i do have to run weep Click to expand... How do you plan to keep the presoak gun from freezing? Are you concerned about the additional water use?
OurTown Well-known member Joined Nov 8, 2017 Messages 3,770 Reaction score 1,507 Points 113 Location Ohio Sep 16, 2021 #6 You might consider a blow down/anti-freeze system.
W washnshine Well-known member Joined Feb 21, 2014 Messages 2,058 Reaction score 1,639 Points 113 Location NY Sep 16, 2021 #7 OurTown said: You might consider a blow down/anti-freeze system. Click to expand... Works great for foam brushes -should work for a presoak in a foam gun too.
2Biz Thread Killer! Joined Nov 22, 2010 Messages 2,877 Reaction score 520 Points 113 Location Ohio Sep 19, 2021 #8 washnshine said: Works great for foam brushes -should work for a presoak in a foam gun too. Click to expand... Yes, it works great! Saves a sh$t ton of $$$...Who can weep water for LP functions when prices are close to $20 per 1000 gallons of water+sewage?
