My middle bay was ever-so-slowly dropping in pressure, and it got to the point where opening the regulator valve to full only allowed (tops) about 800psi. The hoses, boom, and wand were also vibrating although I couldn't pinpoint the source.
I successfully replaced the regulator valve and I was able to up the pressure a bunch-- back to normal of about 1,000 psi. The vibration almost completely went away, with just a trace/hint of residual vibration.
Now, a week later, the vibration has increased a lot, the pressure has dropped a little, and I don't know why. The boom, hose, and wand all vibrate and pulsate but the motor and pump don't seem to be abnormal at all. And, the water coming out pulsates a bit as well.
I know this is going to result in a failure soon-- anyone have an idea of where I should start hunting to identify the trouble?
Thanks!
Thanks!
