What kind of tip protector? If order from KR, then what moxel # m
We’ve used a 1505 nozzle forever. The customers think they are getting a lot more pressure than they really are because of the narrower spray pattern. It does take a little longer to rise off the car but it makes cleaning up the bay a lot faster and easier.
How do you apply the tip protectors? Do they just slide over the tip or do you remove the tip and screw them on with the tip?
Try using a 1505 nozzle. That’s the nozzle we’ve used forever. The narrow spray pattern gives the customer the impression that they are getting a lot more pressure than they are. When they pull the trigger they get the kick of the gun and they like that.
MEP, maybe you're thinking of a different kick. ..
Agree. You want the customers to feel the gun push back due to the pressure when they pull the trigger.
So, what do you guys reccomend tip/ pressure wise on regulator i use to have that?
