I have a Ryko Softgloss and the small led screen that gives you the two digit codes when there is a problem is malfunctioning. I can only see part of the left digit and none of the right, making it impossible to check codes or test functions. I have had this problem before but turning it off then on again usually fixed the problem. This time it has been 3 days with no change. Is this something that I can fix, or do I need to replace a part?
