My self serve bays use Cat 623's with Paraplate BR5's as regulators. On one of my bays, the "bypass" sound is higher than the other bays. One of my attendants noted, "Something about that bay doesn't sound right".
If you put your ear against the bypass hose and compare.....one bay is 2-3x louder.
The output in the bays appears to be normal. I use 2507 spray tips.
Any ideas about what is going on? Is this pump probably bypassing more than the others? If so, what would cause this....an obstruction in the hose and/or check valve feeding the bay?
