The original pump in question draws from a warm water rinse tank. It is fine when it there is no cycling weep.
The HP hose runs from the pump down to about the ground, and then heads laterally about 7 ft., then heads up into the trough. Creating a "U" from the pump connection to the trough. Is it possible when the cycle weep is on, lower volume of water, that the pump water actually drains overnight and settles in the bottom of this "U" thus the cavitation? I hope this makes sense, getting late over here.
