- Joined
- Aug 30, 2007
- Messages
- 4,293
- Reaction score
- 1,184
- Points
- 113
- Location
- SW Indiana melon fields.
Successful Failure :-(
Well, Jimmy brought his pumps down yesterday. I started with the leaker. Before removing the head (because it's easier with it attatched to the pump) I showed him how to remove the valves and what to look for. All was good with the valves. I only had enogh o-rings for one pump so I saved them for the other pump. Upon removing the head I immediately noticed that the HP seals were residing where the LP seals should. Going deeper, I discovered the LP seals where the HP seals should be. They were also in backwards (spring showing). Obviously, the problem with this pump was improper assembly so I went no further. I installed a new seal kit, with Jimmy close by, and buttoned it back up. This pump is now ready for a few more years of trouble free service once he bolts it back down...WRONG!!!
I got word from JB that it leaked as bad as before...f@#$%k! I told him that it must be a broken plunger or it's bolt seal, or an outside chance that a seal case was damaged or cracked. I didn't feel that it was the latter, since I had just had them in my hands hours earlier. I told him that he could take off the head and check the plungers if he felt comfortable enough. He did, and found a broken plunger. I can't believe I didn't check that, but was so sure when I found the seals in such disarray that the problem was located and nothing more was needed...silly me .
The other pump was a slam-dunk. I removed the valves first, to find the o-rings broken on four of them. The head was also washed out. This pump donated the plunger to fix the other one. I instructed JB to contact Cat about the lifetime warranty on that head. Hopefully, he will be able to build his pump back up when he gets his new head, and oh yeah, a plunger.
So I failed in fixing JB's pump, but succeeded in teaching him to do it himself. That was my plan the whole time
