Ls brothers
We thought it was pump problem so we just replaced a new pump. But it still very slow to pumping the water. Anyone have idea what’s wrong with it? Is it something clog underground?thanks so much for any help!
The flow isn’t that muchDo you have enough water at the inlet of the pump? What about right at the exit of pump is you take the pvc off, how's the flow?
We are well water not city waterSilly question, these pumps can operate on 120VAC or 220VAC. There is a switch on the end of the motor under the cover that needs to be in selected for the correct voltage. Do you have the proper voltage selected?
Is this a reclaim pump or a booster pump for the city water supply?
Pumping the waste water from the pits. The gauge is 150What are you pumping with that pump? How much pressure do you have on the gauge? I looked up the spec's on that pump, it's rated at 55gpm.
You've got a obstruction somewhere in the discharge pipe, the pump pressure shouldn't be that high.Pumping the waste water from the pits. The gauge is 150
[/QUOT
Do you know how can I do?thanks
Do you know how can I do ?thanksYou've got a obstruction somewhere in the discharge pipe, the pump pressure shouldn't be that high.
Where does the pump, pump the waste water to and check the end of the pipe.Do you know how can I do ?thanks
Do you have any idea what kind of tools or how can I unclog the pipe if it’s clog somewhere?thanks so much for you help.Where does the pump, pump the waste water to and check the end of the pipe.
Find out where it goes and see how much flow is at the end of the pipe. Where does it pump to?Do you have any idea what kind of tools or how can I unclog the pipe if it’s clog somewhere?thanks so much for you help.
Ok.I will try on Sunday.thanks so much.Find out where it goes and see how much flow is at the end of the pipe. Where does it pump to?
Replace all discharge pipe and still not working well. So we need to find the pipe which is going to pump for suction.Find out where it goes and see how much flow is at the end of the pipe. Where does it pump to?
