Joswhaha
Howdy y’all, I am noticing a few leaks on the push connect fittings. The only issue I see is if I can turn the valve off to just the one and repair the leaks without soaking everything. Are there some tricks to getting the water to not come back out of the small tubing when I unhook the “manifold” from below the ball valve? Also, are these fittings good or should I be upgrading to something bigger and better?
Thanks
Thanks
