I was thinking of using this stainless manifold for a direct-fed rinse application. The stainless pipe has a 1-inch opening on the inlet and the outlets are 3/8.
I will be configuring this for 7 bays, cat 2120 pmps, 3HP motors, and 2505 wand tips. Additionally the high-pressure soap and wax will be gravity fed. Do you think the 3/8 openings are big enough to accommodate the feed water flow to the pump inlet or will the pump be starved?
