I use a ProCon 106N480F11XX. It is 480 GPH. I have 2 membranes, and I produce about 3.5 of product when it's warm (as in summer), and just under 3 gallons in wintertime. I run almost a 1:1 reject rate, and yes, my unit has a recirculate loop.
Point taken ... not sure how much more the functional equivalent in a stainless Procon Pump would cost $$$. Brass could make better sense considering it is the booster pump that is not pumping the actual more aggressive to brass already made up RO water like the pump that goes to the 6 bays.
Below Here is what I found (links) to match your specifications. Ideally, I would be able to order all of the below from 1 car wash supplier but that might be wishful thinking.
"Low Energy" membranes are available - and practically speaking you can think of them as "Low Pressure" membranes.
Assuming you have the appropriate pretreatment, understand the minimum concentrate flow, and the expected permeate (RO Water flow) given your pressure and water temperature. Check all that against your concentrate and permeate flow gauges and pump pressure gauge.
