self serve bay not working
aca carwash 2
Maryland
MEP, I have a D&S ss bay meter box, I’m gonna try the timer first today and see if that works, if not your correct, I will have to replace the door because the touch pad and door are all in one I believe.
I was looking to replace these at some point, they are 17 years old.
aca carwash 2
Maryland
it was the timer...……………………….hurray. ONLY TOOK A MONTH.
Thank you everyone!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
That's great, I think I told you that it was the timer a few posts back. What kind of timer is it? If it's a Dixmor timer they are repairable. When you shorted out your transformer, motor contactor you blew the Triac in the timer.
washnvac
Seaford, DE
From Randy on 10/31--What kind of Timer are you using? I'd replace or swap the Timer. If the low pressure doesn't work I'd have to guess that the timed load on the timer is bad. A volt meter is your best friend at a car wash, if you don't have one get one and learn how to use it.
Cost yourself a month.
JGinther
Zip-tie engineer
Loveland, CO
Thanks for updating us. It's good to know you got it fixed and also kind of nice to know everyone else has facepalm moments too. Happy facepalming everyone!
