Self serve weep issue
J Weber
I have 3 self serve bays served by a Weep Miser weep system. I’m getting weep output in 2 bays but not in bay 3 ( the farthest bay from the weep water source). What would cause this to happen and what can I do to fix it?
low water pressure, and/or a check valve stuck closed. Some weep systems also have a needle valve that could be inoperative. Find where your weep tees into you high pressure line and remove the weep line there to test
J Weber
Thanks! It was a bad check valve under the high pressure pump.
redlionwash
Hello, I am having the same issue with the weep. All bays except one is not getting water. I changed the check valve, but that did not help. Water is getting through the check valve, but not to the bay. Any ideas?
Thank you
J Weber
Thank you
Have you verified that your wand is the weeping variety? They do sell a non-weeping model.
J Weber
Thank you
Also, check your solenoid valve to make sure it is fully functioning. Sometimes they will get stuck and give low flow or no flow.
