Self serve weep issue
J Weber
I have 3 self serve bays served by a Weep Miser weep system. I’m getting weep output in 2 bays but not in bay 3 ( the farthest bay from the weep water source). What would cause this to happen and what can I do to fix it?
low water pressure, and/or a check valve stuck closed. Some weep systems also have a needle valve that could be inoperative. Find where your weep tees into you high pressure line and remove the weep line there to test
Thanks! It was a bad check valve under the high pressure pump.
Hello, I am having the same issue with the weep. All bays except one is not getting water. I changed the check valve, but that did not help. Water is getting through the check valve, but not to the bay. Any ideas?
Thank you
Thank you
Have you verified that your wand is the weeping variety? They do sell a non-weeping model.
Thank you
Also, check your solenoid valve to make sure it is fully functioning. Sometimes they will get stuck and give low flow or no flow.
