- Joined
- Aug 31, 2007
- Messages
- 6,372
- Reaction score
- 943
- Points
- 113
Thank you but I believe that is the old Paraplate since the new ones don't have a jumper.Here’s the technical sheet http://ginsan.com/techspecs/tg-283 - Sensorton with Cleaning Instructions.pdf
Paraplate Timer to Universal GS-41
Black wire to -Coin Switch
Yellow wire to Jumper for 24 VAC
Red/Green wires to +Coin Switch & -Coin Switch
WHOOPS!! That is the older timer. Try this, Yellow wire to terminal #1, one Red/Green & Black to terminal #2, 3 or #6, one Red/Green to terminal #5Thank you but I believe that is the old Paraplate since the new ones don't have a jumper.
Still not the correct timer. The Blue T24400 has terminals 1-4 Line, neutral, Neutral, LOad. Then it has and Aux + & - and Coin Switch + & -WHOOPS!! That is the older timer. Try this, Yellow wire to terminal #1, one Red/Green & Black to terminal #2, 3 or #6, one Red/Green to terminal #5
Sorry, do not undrstand the "tb" designation.http://www.autocareforum.com/showthread.php?14286-Timer-wiring&p=108124#post108124
The Paraplate timer is 24 or 110 volts.
coin acceptor: yellow, black (tb1)
coin acceptor: red/green (tb2 coin switch)
horn: (tb2 5 volt accessory)
You can still use the Paraplate timer, just use it on 24 volt. I've been using the Parker Grace timer for years and have never replaced one yet. https://www.kleen-ritecorp.com/p-34389-parker-engineering-01-0238-0000-grace-timer-ii.aspxwow crazy , why did buy this silly paraplate timer , it says it can work with 110 or 24 volts but i guess i have it all wrong , i will have to buy
another timer and put this nice new blue paraplate on a shelf to sit and do nothing.
Do you have a 24 volt transformer and a mercury relay?can you guys tell me exactly how to wire a sensortron to this timer , i dont know a brand or anything but i added the pic. Im trying to make a vacuum run i just put up. Do i jump a wire from 2 to 3 then add a wire from the coin acc ? I need to know exactly how. lol thx Dave
You need a 24 volt transformer to power the sensortron.No im not willing to do all that , can i use the timer in the pic i put up ?
