If you have only noticed the springs pieces, but haven't had evidence of seal failure with reduced pressure, chatter, or water leaking, then I would bet that you won't need to sleeve the head - there will not be any damage. Acting soon is what prevents having damage to the head in most cases. All you should need is a seal kit and the parts from the service bulletin by cat regarding the new large springs, spacers, and adapters.
