Small pieces of Spring in Spray Nozzles on LW4000
water guy
I have gotten some pieces of spring in my spray nozzles . I think its was coming from my Danfoss Valves . Any ideas ? Rebuilt my Danfoss Valve seems to be ok .
pgrzes
S.E. Pa.
Probably from the check valves in the manifold tree. I would check the low ph ck valve first.
JGinther
Zip-tie engineer
Loveland, CO
It means you have a Cat 3535 before the updated head components design. Time for a rebuild. :( Those small springs break and then slide into the seals in the pump and cause them to fail. Need to update to the newer pump design. It uses large springs that surround the entire plunger.
JGinther
Zip-tie engineer
Loveland, CO
We have done several while the pump is mostly in place. Only need to remove the head and leave the crankcase in place... Your distributor should be able to do it for you. If they can't... hmm.
water guy
Well I do mostly all of my own service and have changed it once already not hard to do. Just a company to resleeve it is all I need .
JGinther
Zip-tie engineer
Loveland, CO
If you have only noticed the springs pieces, but haven't had evidence of seal failure with reduced pressure, chatter, or water leaking, then I would bet that you won't need to sleeve the head - there will not be any damage. Acting soon is what prevents having damage to the head in most cases. All you should need is a seal kit and the parts from the service bulletin by cat regarding the new large springs, spacers, and adapters.
water guy
I sure appreciate all the Information from Everyone. Thanks Again and Merry Christmas to Everyone
