Source for Main Spray Bar Swivel / Side Trac 700R
Anyone know the original source for this part? It is a brass swivel with stainless insert.
What companies make car wash swivels for pressure automatics that could duplicate a swivel?
Mosmatic, super swivel etc. What size is it, and is it straight by straight or a 90 degree? I get most of mine from Kleenrite in full stainless steel.
well physically it is straight but not sure in swivel terminology; water comes in 2 ports on side. one hp/soaps, the other spot free. outer is brass and inner is stainless. stainless piece has 2 o rings on orifices at bottom; one large one small.
lilb93
Coal region of PA.
If you cannot find the exact part find a good machine shop they would be able to make the brass outside( Which would be worn first) quick in a lathe. Probably the inside stainless would be good just need new o-rings.
even if they could just turn it for you , You could drill the brass in the right locations from the old and retap it.
If you were closer and had the solid brass it would take less than 15 minutes to make.
