Spot Free Plumbing
Kar B Kleen
Need some recommendations on what type and size hose/tubing to run to the bays for spot free rinse and at what pressure to deliver. Thanks for the suggestions.
I use a 3/4 HP motor and 2504 series Procon pump, a 500 PSI SMC regulator, 3/8" OD tubing, and run the pump at 225 PSI.
We are running 400 psi with 1/4" high pressure hose. It's a very noticeable difference from most typical washes.
I have run 450 PSI with 3/8" OD tubing and a 390 pump, I don't think my current cutomers care that it's 225, but the ones at a high end wash do.
Bricks
I don’t mean to hijack, but what the hell. My SFR tank at the new to me wash is full of algae. Do you know what causes that?
If it's green, it might be tire cleaner. There's something contaminating it for sure. Spot free water should be too clean for algae to grow in it.
BrookMunshi5
I have been looking for necessary information about plumbing on forums, YouTube, etc. I’ve read so much information and concluded that I couldn’t even fix a faucet alone. It makes me feel like an inferior man. I agree that it sounds weird. I’ll have to go to a professional for help. My neighbor advised me of a service that could helps with emergency plumbing: https:/emencyplumbingoncall.com/ . Surely there are those among you who have appealed to them for help. Share your opinion, please. I will be glad of any advice and feedback
water guy
Wow you're in for one helluva ride in the Carwash business
