I have lurked around here because it's the forum I have found closest to the topic (particularly your Lube forum) I'm interested in but I know that Lubes are about as far as this forum goes into the car repair business, but I need some opinions and hope you can share yours.
Assuming you had the equipment and a competent staff to perform any of the following, but wished to limit your menu of offerings, which would you chose:
Quick Lube
Tires
Brakes
Air Conditioning
Shocks/Struts
Exhaust
Alignment
Hand Wash/Detail
Other
Here's the background. I own a building that presently houses a muffler shop and has been one for 30 years. The muffler business here isn't carrying the weight and the present business owner has expanded into all of the above plus fairly substantial repair jobs. It's now a muffler shop plus a mechanical shop. It's about to close and isn't doing well enough to keep the same model. It relies on the owner's particular mechanical skill.
I like to compare one of the problems to a restaurant. They might have all of the ingredients to make a meat loaf, but if meat loaf isn't on the menu, the restaurant isn't going to serve it. This present shop is making way to much meatloaf on demand.
I'm trying to decide with a clean and blank slate (ignoring the competition for the moment) what are the best things to have on the menu in today's environment. Since I own the building and overhead is minimal and can buy the equipment right, I'm eying this as a test case to find a recipe that is repeatable. Thus, it can't be something that is dependent on the exceptional skill and reputation of a particular mechanic.
So, if you don't mind, share with me your vote for a limited menu from the above that you would build an identity around given current margins and economics in the auto repair industry.
If you know of a forum where this topic would fit better, please direct me there. Thanks
Quick Lube
Tires
Brakes
Air Conditioning
Shocks/Struts
Exhaust
Alignment
Hand Wash/Detail
Other
