PTZ Cams
I wouldn't put cameras up if I didnt have a couple PTZ (Pan,Tilt,Zoom) cameras. They can be programmed to sweep back and forth and slowly zoom in and back out, then pan the other way and zoom again. Or I can operate it from my Iphone anywhere in the world or with a joystick inside the mech room. I have them mounted on the back of each vac islands facing the wash bays. So you can capture tag numbers if you want or can make in identity off them if you need that. They will actually turn around 360 degrees if you want to pick up other areas.
