Tips on Increasing RO Output
Thanks for the tip MEP. I am hoping that I can get by at least initially with the 1/2"...I have quite a few things I am still working on to get the auto in and if I didn't have to replace all my lines right off the bat, that would be beneficial.
Mep - Do they stock those at the local hardware or Home Depot? With all these upgrades I'm doing to the system, I need some more (larger) fittings and ordering them online is such a p.i.t.a.
Home improvement centers won't have them. You might find them at a good plumbing supply, but you'll get better quality fittings from Windtrax at a much better price.
These fittings seal at the flare, not on the threads so tape / dope is not necessary. Hoses typically use female swivel ends that fit to a male nipple, so changeouts are quick. The thread on a JIC fitting is 37.5 deg, flare is 45 deg - they do not interchange. Other than online, hydraulic shops will stock them.
