Tire Cleaner - Foam Help
trs246810
Where/how would you recommend the mixing of the tire cleaner and air for foaming? I'm going to add a regulator to my tire cleaner...but this is where I'm at so far. I'm using a procon pump.
Fatboy769
Living the American Dream
Irmo, SC
Assuming the chemical line runs to the boom in each bay, I would run the air the same and t it in there.
I run tire cleaner and air through the same check valve, just tee'd together along with the presoak liquid each in a separate hose/tubing.
My Tire Cleaner and Pre Soak both have "Air Assist" Rotary switch opens solenoid for the same air line "T'd" above boom.
trs246810
T'd above the boom, or in the pump room?​
1/4" tubing sufficient for the air?
trs246810
I like that they share the same air line...very good idea. I'm in the process of finally adding low pressure presoak with "air assist". 👍
I run presoak and spot free through 3/8" tubing. 1/4" is plenty for tire cleaner, foam brush, low pressure wax, and trifoam (unless the run is over 100'). I have one bay that I couldn't bet enough liquid to the trifoam even with the pump at 90 PSI, eventually had to replace that one line with 3/8".
trs246810
what about your air assist tubing? 1/4" okay for air as well as the tire cleaner?
