Touchless Front & Rear Eyebrow removal
i have no interest in any hf chemical for touchfree. its much too toxic and i think it's harmful to car paint long-term. i'll sacrifice a bit of cleaning to be safer and healthier. what's your health worth???
regansf
Hi there, currently doing 2 passes hi, dwell, then 1 pass lo with Blendco products. i notice a lot of companies starting to go with one pass only of each, so I’m thinking just to slow my hi down applying more product and just go with the one pass of each. Thoughts?
traveler17
SE NC
Don’t think that’s some kind of new concept. One low , one high. I’ve never heard any benefit of running 2 hi’s , sounds like dumping $$ down the drain.
ShinePro
Xenia, Ohio
I ve stayed off this page for 2 months
After the show in Vegas I got a delivery of new stuff
Been testing for 50 days now
I was doing a great job cleaning cars
But I got better
Will be allowed to report more soon
But I got better
Ok SinePro, come on with it....😏👊
ShinePro
Xenia, Ohio
Ok
So I had to revive an old thread
My rep was here today - we were testing a ceramic product in the self serve bays
After that and dinner
We drove 30 miles to go see a Double Barrel Razor that I heard had been installed earlier this summer
First time for me to see one work
Anyhow- very impressed with how it worked. Nice unit!
But-
I had not washed my truck for 2 weeks
(Lots of rain here and and field work before that. )
So I had a decent eyebrow.
I m pretty confident I know whose chemical they use
But that fancy double barrel did not touch my eyebrow.
So we drove 30 mile back and got it off with the Razor 3
Bottom line is - equipment doesn't get cars clean
Properly programmed and applied good chemicals DO!
jack954
i would agree that properly titrated quality chemicals are most important. however, there’s a lot more to it to clean touchless in tough conditions. soft water is a must, hot water helps, dwell time very important, closer the water pressure the better. to take it one step further, having a door closed on one end of the bay during windy days so the chemical actually makes it to the car.
ShinePro
Xenia, Ohio
Well yea
All of that
And water temp etc etc etc
My point to this was-
With all the chatter on here about whose unit should I buy
Touchless- friction- combo
Razor - istoball- petite - on and on
It doesn't matter if you don't have it set right with good products!
One of my top ten comments on here that I’ve read was on a thread about equipment.
I forget who but it went something like this
“ buy your equipment from the best distributor you can find regardless of what they sell”
I cant argue with that!
This thread is about eyebrows
My opinion is it does not matter what equipment you have
It all comes down to chemistry!
And that has been my point from the start of the thread.
JJDPM
I have chased the eyebrow removal unicorn for 11 years. Finally was able to get it removed using Viper from Synergy. It's a polymer and I only apply one heavy pass. I have it working great at one wash 95% of the time on my G5's, trying to replicate it on my Razor now at my other site. Not sure how good it will do as the weather warms, but the past couple of months it's actually done it.
I tried the viper for presoak. I am having a difficult time cleaning the front and back windshields. The back windshields are the worst especially with some taller SUV's. What tip are using? Are other information would be appreciated.
Roz
Amount of chemical with a touch free machine matters. We always tip a size or two stronger for Hi/Lo pH than the recommended amount which seems to really clean cars...
JJDPM
Anyone with a Petit - I am having a hard time cleaning the vehicle. Eyebrows are difficult with the back being the worst. I am also getting some haze on the vehicle. I currently use synergy chemicals. How can I correct these problems? Please HELP!!!
SuperShine
Vancouver Island
I have Petit’s too. Synergies great stuff.
Which tip and injector are you using with Viper? What’s it titrating at?
Have you tried Wildfire in place of the Viper?
What’s your general region?
Cheers
JJDPM
Viper- blue tip on A1/ B1
Tried Wildfire with black tips on both without any improvements.
Viper drys better than the wildfire
There seems to be a haze on the vehicles.
bronze- 4 pass 1.PS. 2. dwell 3. HP with cherry poly 4 . Spot free
Silver- 4 pass 1 .Ps 2. PS in the triple foam 3. Aquagaurd on High presure 4 Spot free
Gold- 6 pass 1. PS 2. dwell 3. PS in triple foamer 4. aquagaurd in high pressure 5. Ceramic. 6 Spot free
I have two sites with the same issues. I called synergy and he came out and looked at everything.
everything in new at both locations.
Northeast Ohio
Any help would be appreciated
ShinePro
Xenia, Ohio
So I was going to get into this but stopped
But now I m Curious!
( I m on my 2nd bourbon here so bear with me)
If he came out and looked at it-
What did he say?
Did he not gave a solution?
