Tri foam coverage
chaz
Cincinnati, Ohio
Hi all,
Recently my tri foam coverage on my auto (Mark vii gt700) has been less than exciting. After checking everything I could. Air, looking for leaks and even switching out to new drums of chemicals still no improvement.
Then the light bulb......
Replaced the foam pieces in each of the 6 foam generators....looks great, I mean really great.
My generators had foam cylinder shapes like room A/C filters...I used the plastic dish scrub pads as an easy to source replacement.
chaz
Cincinnati, Ohio
Yeah...thought about the stainless scrubbers....but went plastic cause of the small opening to shove the scrubby into.
chaz
Cincinnati, Ohio
I removed the old foam and stuffed the new scrubby in to the tube. I used about 3/4 of the material. Like I said I went with plastic do to tight space to shove the stuff through
rph9168
Carwashguy
Atlanta
It is important to clean or replace those scrubbies as part of your regular maintenance schedule to keep your tri form at its best.
Ayerule
FL
Went stainless scrubbies too. I split two pads for my three tube generators. Stretch them out and use a long screw driver to shove them in there so the pumps don't have to fight so hard. Lower pressure, less chemical, better results.
Car_Wash_Guy
out west
Didn't know that. My foam is weak - who knows when, if ever they were maintained. Guess I'm gonna go up into the trough and take a peek. Thanks for the info!
