Undercarriage width on LaserWash 4000 ?
What's the width of your undercarriage side blasters?
Mine are barely wide enough for a car, & 1 side or the other is ran over EVERY time a vehicle comes in. When I have 4x4 trucks or duallys, both sides are ran over by tires? Surely this isn't normal ?
PEI
Danville, VA
The undercarriage should be 9 feet from the center of your side blasters. If it is shorter then you might want to add longer nipples on each end. Just remember to add the same length to both ends to keep the undercarriage centered.
PEI,
I don't understand..... 9' from the center would put it well in excess of 18' across....? I'm going to measure mine today & get back with you guys...
PEI
Danville, VA
9 feet from the center of the side blaster pipe on the drivers side to the center of the side blaster pipe on the passenger side.
Oh, I see. So basically 9' from 1 side of outter blasters to the other...?
Mine was 7'6", & we extended to 9'. It's probably 6" too wide for small cars, but perfect for truck , SUV'S & Duallys. Thanks for feedback
