I can’t figure this out.
The soap draws past the Kip solenoid when on rinse. I can watch it travel through a clear line to the check valve at the pump. I tried a brand new solenoid and then swapped wires from the wax solenoid and put a new rotary switch on because it had a lot of play in it. I checked and got 24VAC at the solenoid when soap is selected and none when rinse is selected. Futura pump stand. One bay works. The other one is drinking soap until I turn the knob off on the flowmeter. Does anyone have any ideas?
