wendy's wash
Morning everyone. This morning got to wash and found my JE adams vacumn had been pryed on to get to the money. The vac is 13 years old and has a pin lock type box. Who ever tried to get to the money also smashed the coin mech door. I was able to make coin door look back to normal. Just hammered from inside and replaced decals. Looks good again. The problem is the coin box. First I could not even get the key in as it was at such a bent angle. Hammered on pin weld and got key to at least go in and turn. Lock won't drop off pin and come out. The face of the box is bent bad and I can't reshape it till it comes off vac. I have 2 thoughts. 90 degree drill for lock or a torch to cut away lock. I am worried about hurting the welded pin. Does anyone have any other ideas or have had to do the same on vac before and tell me which one would be better. Thanks.
P.S. No money was lost.
