Vacuum dome lights not working
Thunder sudz
Customer informed me that the vac lights on the dome are bot working so I replaced the bulbs still no lights. Any ideas to point me in a good direction
mucoucah
Corpus Christi, TX
Which vac manufacturer? In mine the lights are wired independently from the vacs, so i would check for a breaker tripped or damaged wire somewhere that killed the lights but didn't affect the vac.
Thunder sudz
I'll check the manufacturer cause I'm am not sure.
But should the lights kick on with my timer? Or just when the vac is running?
mucoucah
Corpus Christi, TX
If they were wired like that then yes. Check the other vacs, that will give you an idea how it is wired.
Dick Nitro
If they actually have power and work otherwise, make sure your socket is clean and corrosion free. It’s a rough environment up there and I’ve had bulbs not work due to oxidized/dirty sockets a few times
Colemans Supervacs had a photo eye in the front shroud. That way they only came on at night. So, that is a link in the chain to check
Thunder sudz
Thank you. The eye was corroded.
Cleaned both and now I have light!!!
Thank yall for all the input
Rudy
Pennsylvania
After 30 years in the business......I don't see a nickels worth of difference between having those dome lights work or not. I quit fixing them years ago.
My lot is well lit (and clean).....and that's what really matters......
