We use these also, good suction and life out of them.We use the KR VMK19 Vac motor. When you change motors to a different brand, you always want to use the same motor so they all turn at the same RPM.
They are good motors, they are made by electroluxWe use these also, good suction and life out of them.
My reason is the VMK19 is 20% less expensive and they run long and strong.So I've been using the cheap Lambs for years. I'm curious why you guys don't use them. Their longevity and suction seem fine. Any input?
Loading…
www.kleen-ritecorp.com
I am getting to the point where I don't bother changing brushes. When one goes out I just change them all three out for less than $200 and they're good for 3+ years.
I am about to convert to some two motor vacs (from three motor) so if anyone can attest to a significnat increase in performance I'm interested.
We use the vmk because they are cheaper like edredtop mentioned. I have my guys replace brushes when there is extra time and rainy days. I didn't replace brushes when we did everything ourselves, wasn't worth the time, we would replace the motor.So I've been using the cheap Lambs for years. I'm curious why you guys don't use them. Their longevity and suction seem fine. Any input?
Loading…
Replacing the brushes on a VMK19 motor is about as simple as it gets. They are a lot easier than on the Lamb motors. The hardest part of changing the brushes on our VMK-19 motors is taking the top off.we use the lam motors, the reason is Vac brush replacement is losing 2 screws to replace brushe, vmk motors are harder to change out due to using a metal tap to get under brush's,
