Want to Install Treadle Buzzer or Horn on WW1.0
Buzzie8
Pittsburgh, PA
I want to install a treadle Buzzer on my Water Wizard 1.0 to notify drivers when they are positioned correctly. I am not sure where or how to wire it so it only goes off on entry and not every time the treadle is pushed down. Also, if you have any ideas on what horn or buzzer to use it would be greatly appreciated.
Tom Thumb
Orlando,Fl
I have two in use , been running for over two years.
Brought horn from WW Grainger and have time relay mounted on shelf with stop light on ten position lights.
when stop light comes on horn sounds for time set on relay, very reliable and not expense.
if you would like part numbers on items let me know.
Reds
Northeast Pa.
Here is some info on the horn that was installed with my WW2.0:
Federal Signal 350-120-30, 350 vibratone horn, 350WB-waterproof, Gasket K8435666A, Coil KFC1516C, Volume control K8435663B
I believe grainger sells them.
Buzzie8
Pittsburgh, PA
I wanted to post this again without all the grammatical errors. I do a quite few of these posts "on the fly" and when I review them later I realize what a stooge I look like. So here it is:
Just curious... if a vehicle drives past the treadle, then backs up, does it sound again? I am assuming it would if it is wired to the stop light. Also, how long do you program the relay. I'm assuming it is just a second or two correct?
Bill is there anyway to delete or edit posts later?
