dbrown2911
Yes thanks. However the plugged tip was on the gun that I was troubleshooting with in the working bay. Think the regulator and bad check was main issue..I turned drip off when I had pump apart then came back a few days later and other bay had plugged tip and the pressure reg was working as it was supposed to. Thank you so much. The pump is going out on it too I think after all that. It's turning hard so think I am going to replace it.
