GoBuckeyes
Self-Serve and Automatics
Maybe someone out there can help me with this intermittent problem. I have a WSII that I upgraded in December with a new cpu board. The board is a revision G with the latest software 555. I did this so I could upgrade to a dual sided card reader. About a month or so ago the credit card reader would go dead. It wouldn't acknowledge a card swipe whatsoever. It would happen maybe once a week at first. Now it's happening every other day. I also noticed that now when this happens the MagPro Bill acceptor will take bills and not issue any credit. The bill pulses show up on the door led but the wash select doesn't give credit. The voice also stops working. I figured it was a problem with the new board so I swapped it out yesterday with a newly serviced and upgraded board. It's a revision E-s with 555 software. It was updated to be compatable with the dual sided reader I want to put in my other WSII. Well, you know what happened...sometime this afternoon it went dead again. I went down there about an hour ago, no acknowledgement of swiped cards, no voice and it would steal every bill you cared to insert. What could be causing this? Would a bad dual sided reader be a possibility? I have a new reader coming tomorrow I will put in. What about the voice board? I could swap it out with my other machine and see if it follows the voice board. I need ideas. This is probably the best car washing week of the year and it's not easy to trying to work on a machine in between washes and it's harder to just be at the mercy of this paystation when you need reliability. Thanks.
