WashWorld New Razor Hyper Force
I'm wondering about weeping on the side arch, I was told this was a single "bent" tube on side arch which would seem to create an issue.
I'm assuming you could increase speed on sealant flex passes and rinse. Not sure I would apply soaps on a fwd/rev pass need dwell time for those.
As I said in my basic report.
I see no reason why the new arch can not be installed on existing machines.
Will they sell us new arches?
I have been working on a farmer engineered replacement for the flex pass pods.
I was not able to open the hood and see how they connected this to the frame.
But I m sure it can be done
Other than that its programming and pomp!
I m assuming from my conversation with my rep that this got dumped in Their lap at the Friday meeting.
Cause he texted me Friday night!
Lots of questions to ask.
Until I get concrete answers - its all speculation as to how WW is going to handle this
My thoughts exactly, as I stated above. Use blue arm for PS, cause you need coverage & especially DWELL
Thanks for the report. If its a modified Edge, Im thinking it has the hyperflex as standard equipment. It is my understanding that you can apply 2 products at the same time with that feature. The video appears to show that as well. I didnt add that to mine because i can only see where it saves me one pass on my top package. Im like you, i need to see the banannas in person. I plan to use those for my med pressure waxes for sure. I feel coverage of those products will be sufficient. Might use it for more after i play with it. I am told that the only one running is at the factory. I looked at flights last night and plan to go in the next 2 weeks. Still lots of unanswered questions.
