You can order only the low-pressure seals, but as I said above, if it's not leaking water on the floor they're probably not bad.Rudy said:Since the seal kits only come one way, I'm going to change the oil, and keep an eye on it. These pumps are like tanks. Mine are 15 years old, and haven't given me a bit of trouble.....
The oil seals only keep the oil in the pump. They do not keep water out.Kevin Reilly said:If the oil has increased in volume and has moved above the sight glass then it's time change the oil seals.
