Weep getting back into rinse tank
GALESBURG LASER
Illinois
I have a problem of weep water getting back into my self serve rinse tank. At this wash i have 2 automatics and 4 self serve bays.the rinse tank has check valves below to prevent this. i drained the tank down and watched the water slowly rise thru 3 of these check valves.So i replaced 3 out of the 4 and that did not help.So i dont know what to try.Any suggestions? Thanks for looking.
Jim L.
Florida panhandle
Navarre, Fl.
I’ve had check valves not want to seal when the flow was under very low pressure. To fix this I took the spring out of the valve, stretched it a little and replaced it. If that didn’t fix the problem I stretched it some more. I’ve always been able to make them work.
There are many different kinds of check valves. I would try a different type.
GALESBURG LASER
Illinois
weep in rinse tank
:)Thank you for the replies! I have ordered a different check valve style. Ive not really had this problem before to speak of. I also had thought of the low pressure not holding check valve closed,so i will try the spring stretching as well. Thanks again!!
tobaccofarmer
I find it interesting that the two best check valve companies (checkall) and (swagelok) are not sold through the two biggest carwash suppliers? I can definetly tell you that when you replace the normal junk check valves that are on 99% of carwash equipment with checks from either of these companies your problems are solved for a very long time! Im not associated with either company either, just many years of testing has proved this to me.
