What setup do you all use for day to day steel and stainless steel weld fixes. Need to attach some vacs. It would be nice to have something simple to do minor repairs. Thanks!
What are you attaching vacs to? I recently repaired an Adams vac that had two of the mounting tabs broken off - I used a Unistrut "L" bracket and bolted it to the vac with a carriage bolt. Looks fine and it's much stronger than it was.
I 2nd MEP's suggestion. If possible a Nut and bolt fix - Stainless if possible will offer a great solution.
Concrete. Do you have pics? The brackets for mounting in the vac are in bad shape. Some of them only have one that really works. I'd love To know how your fix looks and works. Thanks!
